- 12:59 AM
- Dec 3, 2015
- Banner Springs Tennessee
Then we should need less blowdown? We want to overscavenge intentionally?
Exactly. The 562XP has about 10° BD stock.
So you are pushing more of the fresh air and some of the fuel charge out of the cylinder with the longer duration.
My question is if the carb is compensating for the proper ratio anyway, what is being accomplished?
You're assuming that the fresh and mixed layers are mixing in the combustion chamber. According to everything I've studied on these engines the fresh layer is just to push out spent gasses. I'm sure some mixing does happen though.
Yes I suppose I was...
For the saw to tune right, I would "think" it would have to...
However if the saw runs better, your theory that it may not sounds plausible. Either that or the extra fuel charge passing through the chamber could be helping cool the piston and cylinder more, thereby allowing more charge to get stuffed on each stroke.
Thoughts?
I sure won't pretend to understand these engines completely.....because I really don't.
When you can, look at the piston sides on a strato saw. The fresh air passes across the cut outs in the piston, so it has to cool it I think.
I see more strato saws with fried crankshafts than regular saws.
I know you have ported while keeping the stratos, and gutting them. Do you see an advantage either way?
Not normally. But the MS241 really gains from gutting them.
I try to find ways to make sure the spitback mixes on all of them. That makes a bit of difference too.
Enough about saws. Lets talk about farming now dot dot dot
That's a real log you're cutting on there. Fine saw!!
Safe to assume they got stronger as you did more?That was one of the first 441s I did......
Ive been studying a 261 jug recently. One thing I have found curious is the strato charge is not under compression from the downward stroke of the piston and the charge is only directed toward the secondary tranfers. Look at the piston, the strato charge is contained to the cutouts and pin area.View attachment 58297
