blsnelling
Friend of the Riff Raff
- 10:46 AM
- Jan 8, 2016
- Franklin, OH
I believe boost ports on bikes and sleds are typically fed from a different source. These fingers are feeding from the same source as the original transfer port.I don't think the model crowd or the bike crowd bother to debate it. Boost ports are nearly always as standard or added. And a fair few older karts motors had them, if not all.
Fingers do move flow to the back of the cylinder. However, widened transfers direct their charge to to same area if shaped correctly.
I've admittedly never tried finger ports. This is just my opinion. Honestly, I hate to remove that much cylinder surface in a work saw, the same reason I'm hesitant to use epoxy in a work saw. I've seen it work, but when might it fail. I don't want to go there. Again, just my perspective on it.
In a race saw, additional boost ports are often added, but done so through externally molded ports.
