Adirondackstihl
- 5:12 PM
- Dec 4, 2015
- Upstate NY
‘‘Tis why I done what I did sir!!I've used nuts in the past, but there a pain
I did the same with my hybrid, could’ve bought a new artic 462 for what I’ve got in it.Kinda refreshing to see a real 440/460 being built. Easy to buy a new 462/572, this is the proper way to build the heard using select proven genetics.
Another reason I hated using washersI like the idea that it's a nice clean part that looks like it belongs there.
Was my plan as well. The torch will be out for adding the deflector anyhow. About 2 minutes more work.I used nuts also, pretty sure I welded em to the muffler
Been puzzled by this Hybrid question myself.How did intake duration end up? 158-160?
Smaller case under bigger jug. Not that much different then adding a full circle crank to a 460.
Too much intake, just more blowback. Too little, not filling case enough. Perfect, full case and lots of primary/case compression.
Same size to larger intake tract as a 440.
Puzzling.
I try to look at what Stihl did with timing when they added a bigger jug to the same size case in the same model line. Gotta figure them Germans, with this being their full time job, had to know something.
