HUSQVARNA 395xp new p&c or ?
davidwyby
Rural desert logging
9:50 PM
Extreme Southeast CA
AM cylinders are sketchy. Get a recommendation for a decent brand before you buy one...then probably should still inspect and check timing. (Degree wheel, easy)
Socalmisfit
9:50 PM
California hi desert
So here’s what I came up with, used the acid then sanded on it. It is smooth should be ok. I just don’t want to take out too much. Like I said before I have a new p&c on the way, I’ll get a piston and maybe try porting this later on see if I can do it.
12:50 AM
I’d run that.
davidwyby
9:50 PM
I need to take my 395 apart to weld some cracks and want to port it I think, probably this summer. Maybe we can do two?
Wolverine
dilligaf
12:50 AM
The plating is a LOT tougher that you’d imagine. Can you catch a pick or fingernail on anything?
Socalmisfit
9:50 PM
So I stuck everything back together to do a vac test, was bleeding just a little so I pulled the decomp and no more leak. How’s everyone deleting this. Just plug it off or?
12:50 AM
I’d leave it in. They almost always leak under vacuum because they pull the valve in. Usually it can be held out by hand and it will hold. I wouldn’t want a 395 without a decomp
edited to say without a decomp
jacob j.
Only the weird
9:50 PM
Coastal Oregon
I’d leave it in. They almost always leak under vacuum because they pull the valve in. Usually it can be held out by hand and it will hold. I wouldn’t want a 395 with a decomp
There's a few guys that roll big saws without compression releases, but most of them look like:
Socalmisfit
9:50 PM
I don’t meet to sound arrogant, but I’ve never used it on my 395.
jacob j.
Only the weird
9:50 PM
Coastal Oregon
I used 1 on a 661 stihl the first time I started it. I don’t know why it was so much different.
The 661 (in my experience) has a little more static compression, but the 394/395's end up with more dynamic compression. The early 394s were the best - nearly factory hotrods.
