- 10:11 PM
- Jan 24, 2018
- Extreme Southeast CA
Crank. Deflector and flywheel are kinda jacked up but functional.What u still need dude?
I have 394 cranks, you'd need to find a 394 flywheel to go with it but other than they work the same. I can weld that case half for you.
The air dam over the flywheel are always destroyed and new ones are cheap. https://www.hlsproparts.com/product-p/503464801.htm
What's stopping you from getting it stroked?I can weld it, just need a round tuit.
The dams (and flywheel) get messed up when the coil bolt comes loose, goes for a ride, and ends up under the muffler…
if a 395 crank doesn’t turn up I’ll go with the 394. Man I wish things had happened different and this was an excuse to stroke it…
I might know a guy who would trade a pretty fresh oem non-ported jug for that sausaged jug, ifn that would help.
Crazy talk
Crazy talk
Been there and done that.You should buy it so your next 395 job goes fast.
Not so crazy now.
That doesn’t get wyby a 395 though
Nm, I just met the first person to have ever turned down a ported saw.I might know a guy who would trade a pretty fresh oem non-ported jug for that sausaged jug, ifn that would help.
