395 sat in truck in rain started then died
Normzilla
8:14 AM
Cazadero CA
Good morning everyone my 390 and 395 have been in back of my truck in the rain. 399 was fine 395 started ran a minute. Then died like it lost spark. I parked it in my shed later it ran fine. What would have gotten wet or caused this? Thanks Norm....
ucm931
11:14 AM
Michigan
I'd check the wiring, spark plug insulation, and plug boot. May have rubbed through or is cracked a bit somewhere. Water gets in, things shift a bit while running/vibrating and it ends up being enough to ground it out. Dries out and the path to ground is gone.
Normzilla
8:14 AM
Cazadero CA
Thanks Amigos. Luckily I always carry two saws for that reason. I pulled filter cover all good and dry. But doesn't mean no moisture I guess. On off switch doesn't work I choke or out. But figured it could still ground out of wet
Normzilla
8:14 AM
Cazadero CA
Just never had that happen before.,and thought what if I was packing one saw and I'm a jam how could I revive it in a pinch
5000+
11:14 AM
pa
Pull the wire off the switch or coil.
5000+
11:14 AM
pa
One time I lightly sprayed off a 257 with the hose, carefull not to direct the shower near the switch. Yep, no spark, pulled the wire, ran fine, blew out the switch , ok
kneedeepinsaws
9:14 AM
Oil Country
Try some compressed air on that switch, it could retain moisture for a while otherwise
Nutball
10:14 AM
Mt. Juliet, TN
My dad would leave his saws outside in the sun and rain, and they still ran, Husqies too.
Member
10:14 AM
The 395xp has a little hook in the top cover to hold the spark wire, this can lead to a worn wire and when wet have a short path to ground. I would check the wire for abrasion damage in this area and replace if found.
