Woodslasher
Teh debil
- 2:52 PM
- Mar 18, 2021
- Commiefornia
Up on the block is a genuine 372XPW. I got this as a parts saw off a site member and rebuilt it. The flywheel, coil, and pto case half were damaged so I replaced them with good used ones and swapped over the id tag. It got new bearings, oem gaskets, and oem seals while it was apart, and a new oem piston as well. The muffler I got in a lot of parts pre-modified, while it looks a bit rough it has all the spark screens intact. A few oem modifications I did was installing a black unlimited coil, a wide discharge cover, an X-torq wrap handle since I prefer the larger grip, and a set of early 2071 felling dawgs. The only non-oem part on it I'm aware of is a Wolf Creek Saw Shop aluminum intake flange instead of the factory plastic one.
It's a good saw, but I haven't run it in a long time and I'd rather pass it along to someone who will use it. I'm including the 28" Oregon lightweight bar and 7 good used chains for the same. I'll also be posting up a n.o.s. XPW p/c kit and a 372 parts lot, if somebody wants to do a package deal I'd be on board with that.
One last note, I had a local guy open up the lower transfers to give it a bit more pep a few years back. I haven't taken the jug off to see his work but I've run this for a good while and he's built a number of competition saws so I trust his work. If anyone needs me to pull the cylinder and take a few pics to make the sale I'll gladly do that.
I'd like $700 + the ride, but I'm open to offers.
