XP_Slinger
They’re Just Saws
- 2:35 AM
- Feb 9, 2016
- Central NY
So it made sense to plug the hole closest to the idle port in an attempt to lean the transition mix. Just making sure I’m following correctly.The air bleed/transition holes are an area of dual function in the carb. Not only do they provide the 'transition' of the fuel as the throttle opens, they also provide the air bleed for the idle port - that is, they combine air with the fuel flow to create the idle mixture.
This is the hardest part of tuning a Walbro type carb, trying to get the idle and transition to work.
If you need to lean out the idle, you can drill one or both of the transition holes. If you drill the hole furthest from the idle port it will lean out the initial transition. If you drill out the hole closest to the idle port it will tend to make the initial opening a bit richer.
It doesn't take much to make a big change in the transition holes. Air will flow through a hole is a lot easier than fuel going through it. Going up one size on the drill size can make a big difference - in other words, go slowly and have a bunch of welch plugs handy to keep popping them back in.
