SOLD 372xp heated handle, top, rear etc. $175 shipped
Trader history (1)
Mattyo
Youtube speciawist
3:31 PM
Farmington, CT
Ok, so we have a nearly new 372xp top handle...heated. I have one tank on it, with no damage...its nice.
The rear handle I modified myself to accept an element. Both of these items DID work, right before the flywheel lost some of its magnet... in pieces. I have no idea what happened, but I'll include the flywheel as well. The switch is a single pole switch, I will include the 2 way switch as well, also the av spring w/ the ground is included. Generator is included, with bolts.
$175, shipped, lower 48 only, paypal only.
I have a carb heater, which I will include...it may or may not work. ideally needs a thermostat.
Mattyo
Youtube speciawist
3:31 PM
Farmington, CT
bump.... anyone?
top handle is worth $50, rear handle worth $50 at least because its complete, the rear heated element is worth $35 by itself...its new. ... plus the generator, plus the switches, plus shipping is over $175 in stuff. The flywheel, though the magnet is busted works fine as a flywheel, worth at least $10 (btw, I think its a 385xp/390 flywheel due to the extra fins). seems that $175 shipped is reasonable... no?
idiotwithasaw
2:31 PM
Ky
I've been aiming to hit up my dealer for some used ones. I need a 20 .325 small mount.
Mattyo
Youtube speciawist
3:31 PM
Farmington, CT
best of luck, I don't run that size...
idiotwithasaw
2:31 PM
Ky
What do you run on your 350? Have you tried 3/8 on it?
Mattyo
Youtube speciawist
3:31 PM
Farmington, CT
I have only run 16 325 66dl
95vpx066g I think ...
If I need more bar I grab a different saw :)
idiotwithasaw
2:31 PM
Ky
Not sure if I need it but it's on its way here, thanks Matt!
Mattyo
Youtube speciawist
3:31 PM
Farmington, CT
U said u needed 20 325....
Glad I could be of service!
Derf
3:31 PM
Long Island NY
Hey Matt,
if only I had my old 372xp I'd buy this and slap those bits on there.
Bump for a Grape Sailor.
