SOLD 346/353 parts
husqvarnaxpman
5:58 PM
Mi
Parts left over from a couple of builds I finished lately. All parts are used except for the muffler. Prices do not include shipping.
2 carburetors. One off a 346oe, the other off a ne. El18 and el32. I am going to assume they need rebuilt. $25 for the pair.
husqvarnaxpman
5:58 PM
Mi
353 cylinder and piston. I put a 346 top end on the saw so never ran it. Looks decent. Also a 351 cylinder. Does have some scoring but I think it will clean up. Please look at pictures carefully. I can get more if needed. $40 for two cylinders and one piston
IMG_20210307_133905063.jpg IMG_20210307_133922519.jpg IMG_20210307_133928833.jpg IMG_20210307_133803506.jpg
husqvarnaxpman
5:58 PM
Mi
More pictures
husqvarnaxpman
5:58 PM
Mi
346 ne covers. Clutch cover and tank we're removed from a trio brake saw. Tank has only had two thanks ran through it. Muffler is new but is a cat muffler. Maybe it will be good if someone ports it. Sprockets are the spur type. I would think they would be worth $60
IMG_20210307_134354253.jpg IMG_20210307_134240380.jpg IMG_20210307_134334465.jpg IMG_20210307_134340890.jpg
Bodell0
3:58 PM
Whitewood, SD
JohnnyBlade
JUST GONNA SEND IT
4:58 PM
Momence,IL
I thought @JohnnyBlade was looking for a 44mm top end. I may be in interested in the 45mm action if it doesn't sell Doug.
Yup still is:D thanks Tim!
I do believe hes has a 350/353 cylinder
And a 351 open port cylinder
Both great, but not a 44mm 350:(
Unless im reading it wrong, has been a long day. Damn Mondays:risas3:
cuinrearview
Unskilled Hammer Donkey
5:58 PM
Dowling, MI
Thanks, i knew the 2149 was equivalent to a 351. So im guessing the 350 changed to the 351 and then got phased out to the EPA 45mm version? This is all news to me, i sold a 351 not too long ago:D
The 350 and 351 were not the same construction. 350 was plastic case with bearing cup and 351 was mag. The 44mm 350 became the 45mm 350 with dished piston. The 44mm 351 became the 45mm 353 with flat top piston.
JohnnyBlade
JUST GONNA SEND IT
4:58 PM
Momence,IL
Ahhhh! So 44mm 350 and 351 only differed from plastic to mag case. Same top end. Man i learn something new every day. I appreciate the knowledge!
cuinrearview
5:58 PM
Dowling, MI
Yah know, now that you say it like that, I can't say for sure that the 44mm 350 wasn't de-tuned some either. The only 44mm I've ever been into was a 2149 that ate a circlip.
Johnmn
4:58 PM
Minnesota
Tim I believe the early 44mm 350's and 2150's were indeed the same as the 351/2149 just plastic cases
