If these saws have a heavy spring at the front mount, do they also get a ribber isolator on each side that screws into the tank at the front?
Appreciate the help
It's an option if you want it really stiff for longer bars but normally they didn't run the front two rubber AV mounts with the large spring on the front.
I personally run the spring mounts found on the 288 Lite version on the rear 4, and the large spring on the spike. It seems to keep a 32" in check and doesn't transfer as much back to my hands as the rubber mounts.
