HUSQVARNA 136 bah info
Wolverine
dilligaf
11:48 AM
I have a 136 here, and I thought I had a bah for it.
Fits on the studs but has no hole for oil. Anyone know if I can simply drill my own on this one? When I searched the interweb, this number comes up as a match for the saw.
bagpipingtrucker
11:48 AM
US
I usually use the guide plate to match up where oil holes go.
Homelite collector in training [emoji879]
11:48 AM
Mark with sharpie and drill.
GB bar's from left coast i bought some universal bar's
With no oil hole and drilled them.
Wolverine
dilligaf
11:48 AM
I've used grease in the past to create a witness area. Drill it will be. Tnx.
SOS Ridgerider
Muffler Modded Member
11:48 AM
Central CT
I thought the 136 had an A041 mount that oils through the adjuster hole. There is no groove cut in the hole there?
Wolverine
dilligaf
11:48 AM
So I’ll have to fire the saw up and see where it oils. I’ve found a bunch of bars that say 136 and the majority have an oil hole.
My bah has the holes at the mount slot, which could be JB’d. Good thing I didn’t drill yet. Thanks @SOS Ridgerider
SOS Ridgerider
11:48 AM
Central CT
Does the oiler slot on the saw not line up with the upper adjuster hole on the bar when mounted?
SOS Ridgerider
11:48 AM
Central CT
Your oiler slot and adjuster hole, with the groove cut in it, should line up and you should get the oil to the chain through there. I have a 142 here with the same setup.
939DF521-B1C0-4A5F-9AED-35EA30C088EC.jpeg EBFF7139-A4DA-4BF4-ACB5-9F2D62DEFB67.jpeg
Wolverine
dilligaf
11:48 AM
Slot and hole do not line up, I’m drilling after all. At least I learned something outta the deal.
:SimpHomer:
