10 degree down on the file??
rogue60
6:36 PM
AU
Fail
I was only talking getting a basic cutting edge I didn't take into account the thousands of different ways people sharpen chain.
Chainsaw Addict
GO HOOSIERS
4:36 AM
Indianapolis
Try identical chains 1 flat and 1 10deg. Your saw and your wood cutting. Whatever works best for you is the best .
Sent from my SM-G965U using Tapatalk
Basher
5:36 AM
Canada
Very few people actually take a close look at the cutting edge of a chain/cutter, if they did then they could see what the cutting edge actually needs to look like but since it is kind of on the underside of the cutter most just hope the file or wheel magically makes a good sharp cutting edge. When I taught hand filing it became very apparent to me why so many sucked at it, providing them with guidance, clamp on filing guides and hours of instruction made a very few good chain sharpeners. Only by closely examining the cutting edge can one become proficient at sharpening, I say do whatever the particular chain requires as not all chains are made the same.
