Yes. So a thinner grinding wheel is like using a smaller diameter file.
Again, I have used the 1/8" wheels to sharpen larger pitch chains, but I do this in several passes to create the tooth profile. I prefer using the right size wheels.
A few of the '
mini-grinders' will accept 3/16" wheels. Some of them will, with a little modification for clearance under the cover/guard. Some do not have enough threads on the arbor to fully hold the securing flange nut. A few have stated that they accept 1/4" wheels, but they don't.
A few photos here:
https://opeforum.com/threads/better-quality-forester-grinding-wheels-for-hf-type-grinders.22330/
The 'full-sized' '
clone' grinders usually accept 1/8" - 5/16" wheels, in my experience, but they often come with low quality wheels that do not grind as well as the Oregon, Tecomec, MoleMab wheels.
Depends on what you mean by 'outside edge': you should be grinding with the rim / radius of the profiled wheel, not with the flat side.
Philbert
