084/880 Fixed Jet
jmester
6:42 AM
VIRGINIA
Does any one know if part number 1124 121 5604 fixed jet 1.04 is press in or threaded. I want to put it in a ht5 that's has a press in fixed jet that is going to go on my 880. The ht 5 has a .94 fixed jet that maybe enough jet for an 880. I would think the morefuel the better.
jmester
6:42 AM
VIRGINIA
I think based on some internet searching and pictures that tillotson switched from a press in fixed jet to a screw in fixed jet. There maybe a bigger press in fixed jet but tillotsons part description are about worthless to try and figure anything out.
Moparmyway
Its just a saw
6:42 AM
In a meeting
Jets: (not all are available in all countries)
.46 = 1121 121 5601
.52 = 1121 121 5602
.56 = 1120 121 5600
.61 = 1123 121 5601
.62 = 1122 121 5603
.64 = 1122 121 5604
.66 = 1128 121 5605
.68 = 1128 121 5603
.70 = 1128 121 5602
.72 = 1122 121 5602
.74 = 1122 121 5607
.76 = 1128 121 5604
.88 = 1124 121 5609
1.04 = 1124 121 5604
Carburetors with fully adjustable fuel mixture screws:
044/046/MS440/MS460 = 1128 120 0624 with .70 jet
064/066/MS650/MS660 = 1122 120 0621 with .64 jet
Dual port muffler covers:
044/046/MS440/MS460 = 1128 140 0801
064/066/MS650/MS660 = 1122 140 0800
Looks like they're threaded, but I'm guessing
@Mastermind ??
Jimmy in NC
6:42 AM
North Carolina
Let me get to my IPL and notes today. The 088 carb [Tilly] is a screw in jet. I put an 088 carb and intake on an 880. I ground the floor out of the intake leaving timing alone. It got a 361 coil. Opened the stainless muffler up. With a stock 1.04mm jet it is pig rich and miserable. Swapped to a 1.0mm high altitude and its still rich but better. High side 1/8 out.
If you 880 is otherwise stock or close to it..be weary of changing to a bigger jet as it may not net you what you want.
jmester
6:42 AM
VIRGINIA
Ok thanks for the help. Found out from Tillotson that .94 is the biggest for a ht5. They also told me that with a press in jet you can usually only change them once before they leak around the bore of the jet. I went ahead and ordered a HT 12 because you have more flexibility with set sizes.
Moparmyway
Its just a saw
6:42 AM
In a meeting
Great timing with this ................. where did you source the HT12 from ?
blsnelling
Friend of the Riff Raff
6:42 AM
Franklin, OH
Are you not able to tune it with the jet that's in it?
jmester
6:42 AM
VIRGINIA
I am getting the HT 12 from @fordf150 . They are pretty expensive. I have not tried the carb out yet. I got it years ago as a spare for for my 084. I want to use it now on my 880 . I have found that the jets installed from the factory are not always the best. Sometimes you need to go bigger and sometimes smaller.
jmester
6:42 AM
VIRGINIA
Also got some more information on the jets available for the ht-12 or any HT carb with screw in jet. Tillotson has jets that range from 0.50mm to 1.07mm. I got part numbers from 0.90 to 1.00.
Jet Size. Number.
0.90mm 49-B26
0.92mm 49-B27
0.94mm 49-B28
0.96mm 49-B29
0.98mm 49-B30
1.00mm 49-B31
These go up in steps of 0.02.
Moparmyway
Its just a saw
6:42 AM
In a meeting
I got my HT-12 from M&D, $183.00 delivered
Jimmy in NC
6:42 AM
North Carolina
Jet Size. Number.
0.90mm 49-B26
0.92mm 49-B27
0.94mm 49-B28
0.96mm 49-B29
0.98mm 49-B30
1.00mm 49-B31
Part numbers are only half the battle. Its damn near impossible to order them. I would take an 0.96 if I could get one. 1.04 was huge... 1.00 starting to be able to tune the high but still fat...1/8 turn out is where it is set.
