066 Redeye cylinder
066 redeye
12:57 PM
Tasmania,Australia.
Hi all,do you think this is cylinder salvagable? Was caused by a broken OEM circlip.Running china p/c at the moment but would like to refit original cylinder.Can feel scores with finger nail.Would 800 w&d then scotch bright get it good enough.May get some Caber rings and already have a second hand piston.If the ring grooves cleaned up could i reuse the piston as the rings would still seal?
Cheers,Chris.IMG_20170719_130808.jpgIMG_20170719_130601.jpgIMG_20170719_130636.jpgIMG_20170719_130706.jpgIMG_20170719_130318.jpg
8:57 PM
Cheers,Chris.View attachment 78947View attachment 78948View attachment 78949View attachment 78950View attachment 78951
I would run it lightly clean up the port bevel.
Hone scotchbrite sand etc. Whatever method you choose.
I've run far worse.
066 redeye
12:57 PM
Tasmania,Australia.
Thanks for the replies.Will use good second hand piston I have(Stihl).
Sounds like cylinder could be a goer then?
Cheers,Chris.
8:57 PM
Cheers,Chris.
I've used a lot of cabers they are my favorite but give them time to seat in the f cast are freakin hard if you get those lol
066 redeye
12:57 PM
Tasmania,Australia.
Thanks all,cleaned cylinder up today.All looks good,pics to come later.
I don't plan on using F rings.Are Caber rings advertised as F or do you have to enquire weather they are F or not.
Cheers,Chris.
8:57 PM
Cheers,Chris.
That's all i received the last few years.
I wasn't given a choice that's what arrived.
Anyone know if there is a variety that can be ordered.
066 redeye
12:57 PM
Tasmania,Australia.
Hi czed, I can get the non F caber rings.Just got an email back from The Carby Doctor,located in Australia (where I am).
Cheers,Chris.
8:57 PM
Do what Redfin said. Put a ring in the bore, in the correct direction so you can use a pick to pull it out at the top of the bore.
Make sure that the gap isn't riding over any port opening. Flip the piston over, close your eyes, and slowly push the ring up the bore with the piston a few times. You just gotta get past the exhaust roof.
If it smoothly rides to the top and you feel nothing catch, you're good. If you feel resistance in the same spot a few times, you are not good and you need to check things out.
8:57 PM
Sounds like you're good.
I finish every jug with a brake hone now. Cheap insurance that any small imperfections in the bevels I could have missed will be smoothed. Also any polished plating.
Hasn't failed me yet.
Termitebuffet
Home of the corn can muffler .....
8:57 PM
Midgetville Norf Kacolacky
Like a ball hone ? [emoji2]
