066 red light
deye223
AIR FUEL SPARK VROOOOOM
1:29 AM
G'day all I have an old 066 rl here atm and never worked on one before .
Now I was tuning it and once I get the rev up a bit the tac go's nuts like a limited coil so does the signal that turns the led on interfere with the tac ......
Cheers
11:29 AM
Limited coils will make a tach go nuts when you hit the limiter.
redline4
I'm huge in Japan
10:29 AM
Rosholt Wisconsin
What brand of tach?
I may or may not have not paid attention to the arrow thats supposed to point towards the plug/wire the first time I used my Fast Tach and had some seriously weird rpm readings.
11:29 AM
I have a fast tach tiny tach too, mine kinda gets erratic readings if I don’t get close enough to the plug or in the right spot. But yeah it goes nuts if a saw hits a limited coil.
Deets066
AKA Deetsey
11:29 AM
It’s a limited coil, you can double check by looking at which slot the flywheel key is in.
deye223
1:29 AM
Fast tac it works in the 261 460 and anything with a unlimited coil it is doing the same thing as the 461 you get up to about 9000rpm and then it just go's to
