SOLD 064
Trader history (1)
jk14
11:44 AM
Glenside Pa.
Stihl 064 that I recently purchased with a toasted piston. The deal left a bad taste so I want it gone.
I had a cross/mmws 066 cyl. kit on the shelf so I put it on with a gasket and ran it (reused the oem wrist pin,bearing and clips) The 066 cyl. has a decomp. so I put a hole in the cover to accommodate it (valve is Stihl oem) since I didn't have a plug on hand and the cover is ugly. Saw runs good and oils well, until it gets hot then starts to lose its tune. I didn't press./vac. test it, just assuming the crank seals are shot and caused the original failure. I only put 1/2 tank through it and stopped running it as soon as the tune started going away. Muffler looks like it took a hit at some point as well (see pics.)
The original mahle cyl. cleaned up pretty well and will be included as well as a nice winter cover and another tank/handle. The spare tank assy. took a hit behind the cap and pulled away at the seam( possibly repairable? or junk see pics.) Will also include new crank seals and fuel line.
$425 PHO.w/extra cyl., tank, winter cover., new crank seals and fuel line. paypal f&f or add 4% plus actual shipping for everything
Edit: would take $370 if I keep the Mahle cyl.
jk14
11:44 AM
Glenside Pa.
Extra parts included
20170121_185349.jpg20170121_185413.jpg20170121_185400.jpg Spare tank damage
Mahle Cyl. scuffed but not detectable with fingernail
smokey7
11:44 AM
Detroit
Lets see it run..... I keep seeing all the hype about the 064s I may want my first big stihl to be this one.
jk14
11:44 AM
Glenside Pa.
I can get a better vid. tonight after work, but here's it's first cuts w/the cross/mmws cyl kit stock un-modded muffler in frozen oak with safety chain.
I'll throw a 28" bar with a sharp chain on tonight and get another vid.
Edit: due piss poor weather this evening getting another vid. is postponed
jk14
11:44 AM
Glenside Pa.
Price drop $400 for everything or $350 without the original cyl.
Edit: 1/28/17 decided to take it off the market for now. I put the new crank seals in it today going to run the piss out of it tomorrow and see if I take a liking to it.
