SELLING 044
big t double
You can call me Teddy Eastwood.....
5:20 AM
:( Bummer. Looks like a little bit of some carbon scoring to me. So this isn't for sale any more till I clean the cylinder and put a new piston in it:(
big t double
5:20 AM
Took it down and cleaned it up a bit. Put a little emery cloth to the cylinder...there was no transfer, it was just scuffed so I cleaned it up with finger pressure. Measured the pin just because.
big t double
5:20 AM
New oem piston with new gasket and cylinder screws. The old gasket was the thicker 1mm one for some reason. Found a bulletin that certain ones actually came from the factory like that. I replaced it with the new .5mm metal crush gasket. I test ran it tonight with no bar or chain and it fired right up so it's back on the block. :)
