036 pro cut off head 300psi compression
12:10 AM
I'd tend to agree although some are anal about it that a small 2 cycle gasoline engine will not suffer fuel detonation .If that were possible I'd certainly think they would fly apart like a dollar watch but they don't .I'd also agree you can overdo compression .As a rule those that run extremely fast do not run extremely long .----the life of a racing two cycle kart engine used to be figured in hours ,like under two .
RI Chevy
12:10 AM
earth
Were you able to tach it out when running this saw?
Very cool idea. What kind of studs are you using?
Keith Gandy
Maxima K2 40:1 87 Pump Gas
11:10 PM
Provencal, Louisiana
Figure out the compressuon ratio. Its not as high as you think or it would detonate..
Ill agree. Im not seeing being able to use a vehicle long stroked engine chart to figure psi to CR. Saws r shorter stroked and alot less time to detonate than a vehicle engine the way Im seeing it. Ive seen a few folks on these sites measure CR on saws and seems around 8.5:1 is the usual
wcorey
12:10 AM
ma usa
It don’t work that way.
If the above were true, the vet w/8.5:1 would pump 125 psi.
Actually it pumps 180. High lift & long duration cam to boot.
But isn't that among the differences between measuring 2 and 4 stroke?
4 stroke calculation depends on valve timing overlap and piston speed.
2 stroke once the the piston closes the exhaust port, that's pretty much it...
Nc grease monkey
12:10 AM
Boone, nc
Stainless 5mmx0.8 thread
it wasn't as free revving as one with lower compression, I was afraid to lean it out too much so I kept on the rich side. Could of leaned it out more I'm sure. Think I may do another one just like it and actually take notes and document it properly
RI Chevy
12:10 AM
earth
I wonder if ARP makes studs in that configuration?
Nc grease monkey
12:10 AM
Boone, nc
Don't know, I ordered threaded rod offline.
What I'm wanting to do is take a head cut off of a cheap cylinder and reinforce the holes in it, then machine it to increase compression. Then I can raise or lower the jug to whenever needs to be to get timing numbers desired. Haven't got that far yet 106B9B52-DB8E-4AC9-955B-581678FDACB1.jpg
RI Chevy
12:10 AM
earth
Really cool work. Keep it up. Appreciate keeping us informed too! [emoji106]
RI Chevy
12:10 AM
earth
Looks like it did from the factory. Lol. [emoji106]
Nc grease monkey
12:10 AM
Boone, nc
Need to reinforce the fins we're the studs go through, and make a jig for lathe or milling machine so can get the surface to where it will seal correctly. Not using a gasket of any sort to mate them.
