036 oil pump upgrades.
Jscb1b
Mister Slapnut
11:33 AM
AZ, USA
I've got an 036 that uses half a tank of oil to 1 tank of fuel. Can the pump be upgraded?
WoodAbuser
1:33 PM
Minnesota and Iowa
I don't know of any upgrades to the pump. I will defer to others with knowledge of modifications. However a saw of that age could have a pump diaphragm that is not as pliable as it was when new. Maybe just rebuilding the oil pump with stock parts would help.
Jscb1b
Mister Slapnut
11:33 AM
AZ, USA
I dug around and found you can use 046 parts.
farminkarman
I like the red & black ones
1:33 PM
Neenah Wisconsin
No diaphragm on these pumps. Mods can be done to increase the piston stroke though.
Canadian farm boy
“Normal” people scare me.
2:33 PM
Ontario, Canada
There was an upgrade of some sort that involved the oil pump from an 046/ms460. I can’t remember if you swapped the plunger and control shafts or if it was the whole pump that got swapped. I believe @drf256 has done it. Mayhaps he can shed some light on this topic?
jacob j.
Lord of Cargo Pants
11:33 AM
Coastal Oregon
It's not possible to directly swap the 046/460 oil pump into an 036. The 036 pump uses an external hose ala 064/084 and the 046/460 pump uses passages in the crankcase. I think I remember something about the pump piston and control bolt but Dr. Al would be the guy to ask @drf256 .
2:33 PM
I’ve just modded the ramp and control bolt. Havent tried the 046 parts in an 036 pump. Never saw a reason.
If its a stock 036, a half tank of oil to a tank of gas is pretty good. A ported one can pull a 28 all day, so thats where its needed.
I have parts for both here. I can always look ans measure.
Jscb1b
Mister Slapnut
11:33 AM
AZ, USA
I'm running a stock 036 with a 25" bar and full comp RS33.
2:33 PM
Are you cutting softwood?
Around here a stocker is a 20” max saw. Even my ported one wears a 20”. A bigger saw is simply faster through wood, ported or not.
A 361 and 046 oiler are identical externally. I don’t know if the ramp and control bolt are any different. I do know that I’ve seen new 361 (1135 model) come with an 046 (1128 model) out of the factory NIB.
When I modded the tail and control bolt, the 036 would run around equal.
@huskihl has a thread on how to do it.
If I find the time, I’ll pull the pins/piston/CB on both and see if interchangeable. If they are, it means that the HO oiler parts from an 046 could be put into an 036 pump.
Jscb1b
Mister Slapnut
11:33 AM
AZ, USA
I'm cutting pine, aspen, cottonwood, juniper, cedar, oak, and mesquite. Nothing bigger than 25" dbh except the cottonwood. I wood love another 660, but it is not in the budget.
2:33 PM
