034 clutch drum help
Ronie
10:09 AM
NC
I've been trying to find a clutch drum for my 1988 034 with the small bearing without any luck, can someone point me in the right direction?
Maintenance Chief
10:09 AM
South Carolina
They make a bigger bearing to convert them over to a larger clutch set up, I might have a small one in the shed though. I'll poke around tomorrow and see if I do its yours.
Ronie
10:09 AM
NC
Thanks, I just tried a 660 clutch, bearing and drum on it and it looks like that will work.
Ronie
10:09 AM
NC
The clutch was for a 360, I think.
Ronie
10:09 AM
NC
You can use an 044/440 drum......just gotta tweak your oil pump drive to engage.
Thanks, will the 660 drum work, I can't tell if it will turn the oil pump because I've got to order a new worm drive.
