STIHL 025 runs like a top and dies.
Walden
Active OPE Member
12:02 AM
Gibsons
I received this saw from my Mom's husband. When I got it, it would not idle. I replaced the carburetor, impulse line, fuel line, fuel filter ,air filter and spark plug. Now it starts, idles and revs to 12,ooo rpm (+ or -) but dies upon releasing the trigger. Am I missing something in the carb set up or should I be looking elsewhere? I've note the tank vent sometimes "vents" when the saw is run for extended periods of time. Any suggestions?
Walden
Active OPE Member
12:02 AM
Gibsons
There is no screen on the muffler outlet. I don’t have a pressure gauge to do the testing. I’ m thinking I should be looking into more diagnostic tools - I have a “fleet” of yard equipment that are aging and the idea of just sending them to the land fill frustrates beyond comprehension. Can anyone recommend a leak down gauge that I could use on 2 stroke engines?
Junkyard
Can’t have too many saws
2:02 AM
Claremore, OK
Give it the old brake cleaner trick. With it running spray brake cleaner near the clutch and flywheel. If it dies immediately you’ve got seals out. More often than not I see the clutch side go first.
Credit to Walt @afleetcommand for this trick.
