- 7:11 AM
- Jan 24, 2018
- Extreme Southeast CA
So here I am figuring I’m gonna break something before I get it off, tapping and oiling and heating and tightening...finally it occurred to me to flip it over and tap on the back of the puller bar that I luckily left long and overhung the flywheel...popped right off.
The old style 281/288/394/395 flywheels are a booger to remove. I finally broke down and bought the big puller from Husqvarna just for them.Some of those older Huskys are really stuck.
No I have not read the entire thread but with me it's with the proper tool period.What's the best way to remove a flywheel? I generally avoid it when I can, but beating on a crankshaft 50 times to knock loose a flywheel is ridiculous. I don't like putting a hammer to precision machinery.
Yea, the HAMMER, right???No I have not read the entire thread but with me it's with the proper tool period.
I assume you sent him to get a bucket of steam so you could loctite his lockWe used to treat the new guy to red lock-tite in his locker padlock , at a steam plant I worked in. Time for the universal key!
12 point impact sockets should be outlawed, unless you have a 12 point nut/bolt,,,,, or you hate the guyUm....try removing them after running a 40 then a 60.
The 40 is not so bad. The 60 is a pia to remove. I greased the threads. It helps
Try a quality six point shallow socket half inch drive. Set the ratchet head or breaker bar on a wood pillow block. Pull gentle on the pipe handle or breaker bar.
Sounds like my divorce she was a half wore out unit heading for the scrap heap...Problem with an impact wrench depends on the model plus the air pressure they run on .At the house where I usually work on saws I have is about 100 PSI from a single stage Craftsman compressor .At my shop,22 miles away I have a two stage built from junk dumping into tw0 60 gallon tanks and set to go on around 135 and off at around 155 PSI .Makes a difference .Then again the impacts are not the greatest .Old half worn out production units I got on a scrap pass from work .I had a good at one time but the mother of my children seems to have relieved me of that over 30 years ago due to legal thing called a divorce .
