What's on your bench?
PA Dan
2:51 PM
White Oak PA
MS361 has to have the worst muffler of any saw I’ve worked on.
I’m not sure why they intentionally choked this saw down so badly.
I went right through the front cover on one trying to get the baffle out.
View attachment 200009 View attachment 200010 View attachment 200011 View attachment 200012 View attachment 200013
You are correct my friend! Hope mine sounds and runs better with this one I made!
2:51 PM
with you saying the bearing was bad I thought maybe the worm gear arm came out of the groove on the drum or the arm was messed up
You ended up being right there was a f’n hole in the case where the oiler was. I melted it shut, oiler works again. Must been air getting into the system.
2:51 PM
clutch heat on those are bad on those cases
*s-wordty design ive seen it a couple times melted
Canadian farm boy
“Normal” people scare me.
2:51 PM
Ontario, Canada
Here's what i get to fix forView attachment 200075farwood season
The ms260 was easy. Just a chain sharpening, filter cleaning with general check over and a few test cuts to make sure the tune was good.
The ms250 had a pinched vent hose and the servicing dealer that had rebuilt the carb had used a metering lever spring that was way to strong. I swapped it out with a softer spring from my bucket of misc carb parts and it tuned and ran pretty good.
Now I get to play with the big dog:D
2:51 PM
I got a 288 coming in that has been at a couple different shops.
It's in a bucket now last place couldn't
Fix it after tearing it down.
Same guy wants his 272 rebuilt.
Has 100# comp he says.
Everyone waits until now.
a. palmer jr.
2:51 PM
Southern Indiana
The last saw on my bench (yesterday) was an oldie but goodie, Homelite XL12. Previous owner said he couldn't get it to run and was tired of looking at it. Yes, I guess that type of saw is hard to run without a fuel line....I haven't taken a pic of it yet but it looks like a low hour saw...
2:51 PM
Stihl 25” bar compared to oregon husky 24” bar. Both take same DL count. Thought that was interesting. No wonder the slot needs to be lengthened when mounted to a husky/dolmar. 611A5E2C-1777-4D48-AD47-89E792C26178.jpeg657C000F-865E-482B-9275-80544F778515.jpeg 3B60EE05-4DB9-4D31-BF6F-DDBFB2E13382.jpeg Husky bar on top, stihl bar on bottom. 4498EBE1-D540-417B-8163-DA646F99BE48.jpeg I also had to lengthen the slot on a cannon 28” 91 DL stihl mount bar to fit a 395 with the adapter as well.
460 magnum
1:51 PM
Very southern Illinois
Stihl 25” bar compared to oregon husky 24” bar. Both take same DL count. Thought that was interesting. No wonder the slot needs to be lengthened when mounted to a husky/dolmar. View attachment 200261View attachment 200263 View attachment 200264 Husky bar on top, stihl bar on bottom. View attachment 200265 I also had to lengthen the slot on a cannon 28” 91 DL stihl mount bar to fit a 395 with the adapter as well.
Did you have to make the hole for the chain adjuster any bigger? I have one I'm trying to use on a 576 and the dang adjuster on that one wont fit in my stihl bar. Did know if it was just that model of husky or if this was the case with all of them.
2:51 PM
Yes drill the adjuster slightly bigger on stihl branded bars to fit husky saws. The cannon bar adjuster hole does not need to be drilled. It’s annoying monkeying around with this stuff, but it turns out nice in the end having one bar that fits stihl and husky saws. Saves $.
