What's on your bench?
10:28 AM
it will move over enough to get screw out thaat holds white piece then you need a m5 screw to put in the pump
I’m gonna try this. Thank you
10:28 AM
Ok so get this, the owner of the saw ran it with a chain so f’d up and no oiler output that he overheated the bar, melted needle cage and lost the clutch c clip and washer. “It’s smoking can you fix it”? If it wasn’t a neighbors saw, then I’d say not interested. Lol
PA Dan
10:28 AM
White Oak PA
Everything easy was stripped except for a clean piston and cylinder. I got that one along with a MS250 and a 025C. I need the regular chain adjuster parts to swap the 025 over.
PA Dan
10:28 AM
White Oak PA
At least it was his saw! My neighbor brought back one of mine and said I shut it off as soon as it started smoking! No worries though it was just a Husky!
10:28 AM
is under the clutch melted ? they was bad about that
PA Dan
10:28 AM
White Oak PA
There is more missing than I remembered...that is the pump though right?
