What's on your bench?
beaglebriar
The Peanut Gallery
7:15 AM
Warren Center, PA
Thanks brutha. I’m doing a little here and there. I definitely don’t want to be as busy as I used to be. I’m kinda liking the idea of slacking off more all the time.
Same here. I turned down some work yesterday. Family time seems more important lately.
7:15 AM
I know what you guys mean … I have not built a saw in months … but I have been building some chainsaw wood furniture … does that count???
I guess I just go through cycles!
So Mike, you converted to them other pistons???
7:15 AM
lehman live edge slab
Live Action
6:15 AM
Mn
8A9D7726-CAA7-42A4-9BF0-916F93ADD528.jpeg 2FCE194A-93FF-474E-9DD5-6B7D163F760D.jpeg 0F4FE65B-038A-4213-A041-8CB4D64C7F0C.jpeg 22711980-37AD-4F12-AEE4-312714697967.jpeg E6AEE4CC-815E-4DA3-9ABF-A7D277B8B26A.jpeg
Rebuilt a 200t and all was well for almost a full tank then it locked tight. Found what I thought was a ring location pin but it wasn’t then I figured lover rod or wrist pin bearing. Wasn’t the wrist pin bearing and I didn’t see any missing needle bearing chunks on the lower rod bearing so can’t find where this is from. Old piston had both location pins still and besides that I split cases completely down cleaned in my parts washer, rinsed them off and dried. Got all new bearings and seals then built back up without a base gasket. Measured squish at 22 thousandths without the gasket. Also has a brand new carb but I can’t think of anything the carb could have dumped into the engine. Anything I missed?
7:15 AM
Are you going to leave an open port jug on it???
I’m guessing yes. The saw is brand new and I don’t think the owner would want a used jug on it.
Spoke to @Definitive Dave who told me that the replacement OEM jugs for the 361 are now all open port, no closed are made.
I believe that the replacement OEM MS260 Jug has gone the same way.
This saw is 100% MS361 and my understanding is that this jug came on the MS341.
I’ve got 3 jugs out to port, so I plan on doing them the same way and comparing the open to closed port jugs for performance.
I’m not even sure if I should use the same numbers. I may try to CC the transfer areas in both to see what I am dealing with. The open transfers do visually appear to have a lot less volume than the closed, but looks can be deceiving.
7:15 AM
View attachment 197202 View attachment 197203 View attachment 197204 View attachment 197205 View attachment 197206
Doesn’t the 200T use roller bearings instead of ball bearings?
Did you use oem bearings when you redid the saw? I’d check there.
redlight066
7:15 AM
Taylors SC
Doc, This is pretty interesting. Same bore? Where did the saw come from? I’ve never seen one of those cylinders. Where was this saw manufactured? First digit of the SN
7:15 AM
Interesting Al, keep us posted.
I know my nephew is proud of his 55 Husky because it is a rare closed port.
My understanding is they have good low end grunt but less top end. The only one I ever did was a 029/039 conversion. It ran OK. but I was not overly impressed. But the guy that has it likes it and still uses it.
Live Action
6:15 AM
Mn
Yes all new oem roller bearings but the rollers are substantially larger than what I found somewhere between 3/16 and 1/4”. Still goin to pull it down completely and flush/inspect it again before rebuilding and putting back together. It’s a shame it because it ran great up till this happened. Did just a little intake and exhaust port cleaning and widening.
Disciple of Monkey's
6:15 AM
