What 36” bar for my 395xp
bryanr2
9:19 AM
USA
Been out of the loop for a long time. Largest bar I have is a 32. Who makes a durable 36”? If you have one you want to sell… Send me a message.
ucm931
9:19 AM
Michigan
3:19 PM
Iggesund Forest R2 if You can find one.
Heavy, but good stiffness and durability.
Most likely not much of an option for You, still though I'd mention it.
smokey7
9:19 AM
Detroit
Forrester platinum and GB are my go to favorites. The platinum bar is very good and very hard rails. I like it just as much as my tsumura bars I have. They seem to be very affordable nice and stiff too.
bryanr2
9:19 AM
USA
I have one of those.
3:19 PM
Are You satisfied with Yours?
I like mine very much, though I probably use it much less that You guys use Your long bars.
Price to value was unbeatable, I payed my 36" R2 some 70€uro.
9:19 AM
And I’ve read 404 holds an edge longer?
Yes but it takes more power to pull. Doesn’t cut as fast. If you are willing to accept those trade offs for a more durable chain then go for it. I run 32” and 42” full comp .404 on mine. Just normal Oregon powermatch bars. Full comp .404 is almost the same distance between cutters as 3/8 full skip. The 32” with .404 is real nice balanced to the saw weight wise and power wise. I just put a .404 tip on a 3/8 bar I already had.... it just has to be .063 gauge and you need 95-96DL. I can switch it back to 3/8 any time I want. The 42” is kind of a rediculous size that I only use on the mill or something really huge rarely. Prefer the 32-36” size. If you want to run 3/8... I found a 36” 3/8 with semi skip is nicely matched to the saw. I like semi skip on a long bar in 3/8, it’s 75CK from Oregon I believe. Comes square but you can round file it.
Ryan Browne
8:19 AM
Wisconsin
We must have different ideas of what constitutes "almost the same".
From top is:
3/8 full comp
.404 full comp
3/8 full skip
To my eye, two of them are "almost the same" but it's not what you posted.
9:19 AM
New .404 raiseman full comp with one sharpening on top... and worn 3/8 full skip stihl chain on bottom. Difference is even less noticeable when the 3/8 was new. 6DBB67A9-805E-4699-B008-9BBFD21F2436.jpeg Does .404 chain vary by brand?
