landlubber
Hello,
I'm working on some 026's with the Walbro 194. New kits installed. Starting at 1 turn out L/H.
I have a saw that will start, idle OK for a bit but gets unstable a bit if you tilt the saw on it's side (holds vac and pressure post rebuild). Runs OK in the cut but seems a bit lean. When you let off out of the cut, the saw will take a while to spin down like its lean and it will die and not restart easily. Choke doesn't seem to help. Sometimes the saw won't rev up easily without hitting the throttle a few times. Fuel line and impulse are new and I vac/pressure test from outside the boot so all that should be leak tight.
My thoughts were that the check valve was leaking and allowing air into the L-speed circuit. I've tried to check the check valve and the little disc is loose and I can blow through it but can't pull vac against it. It blows through freely and restricts flow in reverse but isn't leak tight. I tried a few other carbs and they are the same, the check valves don't seal but provide some 'one way action'. Is this normal?
I'm testing with the L screw seated, a nipple into the H screw hole and my thumb over the little hole in the metering area. I can see the check valve disc dancing in the brass retainer when I blow into it.
Thanks
LB
Thanks
LB
