Trollers 181
T.Roller
3:13 AM
Southeast, TN
20170813_175116.jpg 20170813_172657.jpg 20170813_172643.jpg 20170813_171425.jpg 20170812_125526.jpg Alright guys let's get this build thread back up and running. Mike is a really busy guy this time of year and wouldn't be able to finish my saw by the gtg so we decided I would finish it up. All the hard work was done by Mike already I just had a bit of fit and finish to do. First was to clearance the case for the big ass intake block the was installed. I ended up having to grind the case flush and also grind a trench in the block so the impulse would clear. Next will be drilling and tapping the holes in the intake block for the big ass Walbro WB carb. Last will be linkage which looks like I may have gotten lucky on.
Deets066
AKA Deetsey
3:13 AM
View attachment 83281 View attachment 83280 View attachment 83279 View attachment 83277 View attachment 83276 Alright guys let's get this build thread back up and running. Mike is a really busy guy this time of year and wouldn't be able to finish my saw by the gtg so we decided I would finish it up. All the hard work was done by Mike already I just had a bit of fit and finish to do. First was to clearance the case for the big ass intake block the was installed. I ended up having to grind the case flush and also grind a trench in the block so the impulse would clear. Next will be drilling and tapping the holes in the intake block for the big ass Walbro WB carb. Last will be linkage which looks like I may have gotten lucky on.
Intake blocks are a lot of work to make em right.
If I had to do it over I would've had you send me the whole saw. End result would've been better
Deets066
AKA Deetsey
3:13 AM
I used 2 blind hole punches to located the studs exactly where they need to be. They are cheap and work great
