CrystalRiver1
- 6:41 AM
- Oct 11, 2016
- Alabama
Here are a few pics from a downed hickory tree that proved to be at least 4 times larger than the Facebook Ad!!
Edna and I drove out with an initial plan of 45 minutes max in mind.
Simply block it, load it, and if need be, noodle up a couple of the more ornery pieces.
Some 3 1/2 hours later, after snapping a splitting wedge in half, sawing into my cast iron triangle wedge, getting both wedges stuck at least 5 times, getting the MS 261 stuck twice, and ripping the pull cord handle off the MS 660, and almost passing out from the heat/humidity...we finally escaped with this piece of a load!!
Between all the mishaps, being miserably outta shape, the cake thick humidity, and the girth of the tree...this easily qualifies for a outdoor comedy skit or Red Green Honorable Mention!!
My MS 261 with a 16" bar & square chisel is no slouch & munched through wood I never would've dreamed of.
Pretty impressed with the MS660...WHAT A BEAST!!
Stump Shot did a phenomenal job on this saw!!
Heavy as all get out, but I just set it in the Dall---and "Let Her Eat!"
BTW...the so called hickory tree turned out be....Red Oak!
Later,
Reg
Here is the FB Pics vs the actual onsite pics!!
Later,
Reg
