Torque wrech?
Clackb@
Fishguy
12:04 PM
Puerto Rico
I've gone over a bunch of ms660 build videos in rep for my own build. The one thing that is absent in all of them is a torque wrench. Do you guys bother with Stihl factory spec torques on you fasteners during assembly?
NCFarmboy
12:04 PM
Hayesville, NC
I do but I DO NOT use the Chinese screws OEM on cyl. and crankcase. Torque specs are usually in Nm. I use a Snapon 3/8" dr. In lbs/Nm wrench. I do not torque fly wheel nut I buzz it on w/Green Ryobi impact driver.
Shep
12:04 PM
I wouldn’t use a impact on the flywheel nut. I use a torque wrench for that on any saw. I look up the recommended ft lb to tighten to and follow that.
CR888
2:04 AM
We probably should but most don't as issues don't seem to arise from just doing it by hand. After a while you get a feel for what torque all the different fasteners need. We get away with it....so laziness wins.
smokey7
12:04 PM
Detroit
Same thing with wrenching on cars very few things get torqued. If i torqyed eveeything to oem spec id spend most of my day looking up the specs . i wouldnt make any money. You get the feel and trust your judgement and move on.
Larry B
12:04 PM
SW ohio
I like to send my hands out every year to get them NIST/ANSI/ASTM torque accuracy certified. You can never be too careful about torque specs. Next year i may get them Germany certified to the Gutentight standard. :risas3:
12:04 PM
I do it all by feel also, putting a little extra muster on the cylinder bolts and flywheel nut. On the cylinder, I do my pattern several times, and flex that T handle near it's max.
I also use Loctite on them, and make sure the surface of the flywheel and crank have been cleaned. Any grease or oil in there will result in a spin.
Make sure you block the piston (w/rope) and I tighten that nut just short of stripping it with a 1/2" drive ratchet.
After one leaking cylinder, and 2 flywheel spins, you learn to be very careful in these areas to not let it happen again.
Cleaning and prepping of the parts is very important, especially when not using a cylinder gasket. A light sand and clean with brake cleaner is cheap insurance against failure.
CR888
2:04 AM
The OEM workshop manuals usually have all the torque specs for fasteners in NM. So they are available for those who want to use them. I think those who build a lot of saws know what fasteners a vulnerable to coming loose, getting heat seized or causing damage being too tight. They usually use sort of loctite product in some places & perhaps a heat (copper) style anti seize paste on muffler bolts. Or in some cases change out the fasteners to the ones with serrated heads so they stay put.
Lone Wolf
12:04 PM
Nj
Ya!
