Wood Doctor
Edwin
- 8:21 AM
- Feb 9, 2016
- Omaha, Nebraska
I ran into this the other day while rebuilding the top end of a rather vintage Husky 51 that cosmetically was in good shape. It had virtually no comprsesion, the ring was fused to the piston, and streaks were everywhere on the exhaust side. So, I ordered a new top end P/C kit and was installing it.
I removed the four mounting bolts, lifted out the jug, and noticed that not only was there no cylinder gasket, there was no sealer cement separating the jug from the case. In short, the previous mechanic who had installed it simply bolted the jug to the case, metal-to-metal. I've rebuilt at least 40 top ends and this was the first time I had ever seen this on a burned out engine.
So, I have to ask:
(1) Is this a common practice?
(2) Is it a recommended practice?
(3) What are the most likely consequences of doing what the previous mechanic did?
I have always used either a gasket or a gasket cement sealer (Permatex, etc.). To me, metal-to-metal is asking for an air leak and lean burning. Anyway, Forum, please discuss and advise. T.I.A.
So, I have to ask:
