HELP! Tillotson HS
Shane¹
7:36 AM
Kentucky
Anyone know where to find specs for different tillotson HS carburetors? Trying to figure out some differences in models.
Shane¹
7:36 AM
Kentucky
If I can figure out how to read that it may be what I need. Trying to figure out if jetting and venturis are the same between a few carburetors
Shane¹
7:36 AM
Kentucky
Basically want to know have a p100 supposed to have a hs172 I believe. Has hs186 on it but would a hs203 from a 133 flow enough fuel but not be fuel governed?
mgr1
1:36 PM
Belgium
All this information was on Tillotson website a few years ago. There must be post on this forum about the specs.
Maybe that you can find a link from it.
Dolmar hs203 is governed.
Shane¹
7:36 AM
Kentucky
I believe the 123 and 143 carbs were fuel governed but I am pretty sure 133s were not but I may be wrong about that
Agrarian
7:36 AM
New Hampshire
HS-203 - 11/16" venturi
HS-172 - 11/16" venturi
HS-186 - ? but HS-187 (used on Sachs 123) has 11/16" venturi
mgr1
1:36 PM
Belgium
Gonna look at my 133S.
mgr1
1:36 PM
Belgium
133 super carb is governed.
If you have a 133S or 143 with a Sem ignition, the production code higher than 050989 is a limited coil. Maybe are these carb without governor.
