TJ the Chainsaw Mechanic
Old Homelites rule!
- 10:07 AM
- Jan 7, 2016
- Next to my bench at the shop, Oregon
Had an 026 in the shop that had been sitting, went through the fuel system and it fired and ran pretty decent. After some tuning I was running it and every time I would tip the nose Down the engine idle would either severely drop or it would kill the engine.
At first I thought I had set the metering lever to high so I checked with the gauge and it was right on the money. Lowered it a little for the heck of it....no change. Still, every time I'd tip the nose down it would die or idle severely dropped.
So I pulled the carb again and figured I'd check for fuel puddling, sure enough I could see a little ridge right at the cylinder edge of the intake port, And I could see a little gap and wall between the manifold and the intake port....perfect place for vapors to build up.
Is this common? A quick call to JD at stihl tech and I find this was the way they came from the factory. I think I finally have found why I can never get these to tune quite right. JD's "quick fix" is removing the cylinder and lightly grinding the ridge down on the intake port on the cylinder wall. Wish I had some pictures to better show what I am getting at.
Thoughts???
Thoughts???
