PogoInTheWoods
- 5:39 AM
- Apr 23, 2016
- Ohio
Nice little herd, there. I like the variety.
I have a strong dislike for working on an 019t/191t myself.
Get rid of the limiter tabs. Most 064/660 I’ve ran like to be set at 13.5 ish for a work tune. I highly doubt your stock 066 is still fourstroking safely at over 14k. My modded 064 will 4 stroke at 14k but that’s about the edge.Quick question about an older model 066 magnum. What’s best carb setting at about 600 feet above sea level which is where I’m at. I got the old manual as a pdf and it says one full turn on both low and high. Max rpm at 12,000. Idle at 2700.
Then I look at my actual saw and it says only 1/4 turn on both L and H. I still have the original cover on it.... I have also read that max rpm can be set to about 13700.
I’m currently Idling at 2300 and full throttle open at 14600. So I definitely need to adjust it before I start using it.
Advice from the experts please?
