- 10:46 PM
- Jan 28, 2016
- Dike, Iowa
Added you to the conversation. Check your inbox
You should have it.Please Add 1 more.
You should have it.
I've been working on PM850 for a member here, he can announce himself if he wants...
Came in with good compression as you can see in post #1849 above. However, the compression release port was completely blocked so to avoid any risk of leaving some carbon chunks in the cylinder I went ahead and disassembled the whole saw.
While cleaning it I found some chips or notches in the top of the piston, one of which was pretty deep.
Didn't want to take any chances so we agreed on a new piston.
Starting to reassemble I ran into an issue that is common to the 10 Series saws with the bearing insert on the PTO side. With the seal in the insert, it is a challenge to get the seal over the nearly square step in the shaft. The marks on the crankshaft are merely visible, there is no damage you can detect.
Since I work on a lot of these saws, I thought I'd make a simple tool to help with the assembly of the seal to the shaft.
Wait for it...
Mark
Never seen it before. Thanks for response.No bearing in the rod, the wrist pin presses through the rod and the interference holds it in place. No clips to mess with that way.
Mark
Finished this one yesterday but forgot to hit "post". Starts and runs very nicely...now we need a few days of nice weather to dry up the recent snow so I can get to the local brush dump site and test it in some logs before sending it home.
I now have another of the PM800's torn down and cleaned up. I was surprised and pleased to see the cylinder is pristine and the piston has only some light scratches on the skirt on the intake side. Other than that you can still see the machine marks on the piston.
I will need to finish cleaning out the fuel tank and seal it with Red Kote before I put this one back together but I should end up with at least two extra PM800 when this exercise is done.
Mark
