Yesterday proved to be interesting.I went to get the cherry tree that my son & I had cut down last weekend.I took a Poulan 3400 & SP81.I had to quarter the logs to be able to load them & after not even one full cut with the Poulan I found that neither oiler was working.SP81 to the rescue.By the time I got home & unloaded the 2nd load of wood it was 5:00.I still had another ash tree to take down for another neighbor.I took my 81,Timber Bear,& 2 Homies.I dropped the ash with the Timber Bear & did most of the limbing with my little EZ.When it got to the bigger part of the tree I was going to finish it with the Timber Bear,but it got stuck in a cut & I tried to get the 81 fired up to cut out the TB.The 81 wouldn't start.I guess I flooded it.I ended up getting the little EZ fired up & getting the TB freed.I went to fire up the TB again & it wouldn't start.It was running all screwy from last week.It seemed I couldn't get it tuned properly.I replaced the FW seal last month & it was running fine,but now I believe I need to change the clutch side seal.
I managed to get the 81 fired up to finish up on the main stem of the tree.By the time I got home it was 7:15 & I was pretty well whooped.I didn't even bother to unload the last load of wood.I've got a few logs left that didn't fit on the trailer,so now I gotta go unload the trailer & go get those logs.I'm way behind on getting my wood supply in for the spring.Usually by now I've got 15-20 cord of wood in.I've only got about 6 cords in now.
