Lightning Performance
- 3:22 AM
- Jan 26, 2016
- East of Philly
Shults rocker panel guard is from way back when... looks just like it. Must be top coated.Yes exactly, it’s in a spray can and you let it flash then top coat. When I was resorting my car,( I was using the corner of a body shop) he used it an cars and trucks it match the textured finish the factory puts on the lower rocker panels to help with rock chips.
As a side note I have noticed that most of the factory black textured parts have had flaws in them under the factory paint, I am starting to think that Mcculloch used the textured to cover casting flaws, most of the yellow parts looked higher quality...just an observation
On some parts the black paint shows casting fishers if it is the smooth coating.
This sp70 has the textured air box cover, outside only. The over-spray inside looks like Rino bed liner spatter. A clearly defined parting line across the inside of the cover. It would look much better wet sanded and high gloss black.
