The Husqvarna 562XP
Farmchuck
12:48 AM
Nepa
Maybe we can get @Spike60 & @Onan18 to tell us about the less visible changes.
Indeed Randy. Spike & Weimdog did a video this past weekend at Spikes shop on auto tunes. Spike specifically also talked about several changes/ updates such as the fuel line you showed earlier. You can find it on YouTube on Weimdogs channel called afleetcommand.
Onan18
OPE Sponsor
12:48 AM
Georgia
One of the most significant changes IMHO was to the crankcase, the old cases had five screws and were prone to leak bar oil under the muffler. The new cases have six screws and extra webbing to help with rigidity.
Joe
Onan18
OPE Sponsor
12:48 AM
Georgia
Three different carbs, two different intake boots, and I believe that we are on the eighth coil revision. I quit counting how many firmware updates there have been.
Joe
dustinwilt68
Wilt Built Work Saws
12:48 AM
Southwest PA
Soon as they have it dialed in for certain, I want me a 2260, love me the red and black versions and how sleek they look compared to the orange. Diversity is always good in a collection.
Crzybowhntr
Apprentice Slacker
12:48 AM
WV
Crank bearings have been the main problem, I know they have tried different ones several times now
What's the usual run time with ones that had bearings become an issue?
Farmchuck
12:48 AM
Nepa
Any changes / updates slated for the 2017 models?
Locust Cutter
Air Force Redneck
11:48 PM
KS
Hell, I'm just fine then. I probably have 5 gallons though mine since new, maybe more.
awol
11:48 PM
Cabool, MO.
I have also seen three different cylinder types, and two different muffler styles. A while back I had one of each cylinder on the bench; the only difference between the top two, is a drastic change in the port timing.
Locust Cutter
Air Force Redneck
11:48 PM
KS
I wonder if the port timing changes have ultimately helped or not?
Derf
12:48 AM
Long Island NY
I've been doing a little research, and I just wanted to try to contribute.
The major issue Husqvarna seems to be dealing with is heat.
Heat seems to have effects on the bearings, hot starts, differential thermal expansion of heterogenous materials next to each other (eg aluminum and plastic, or aluminum and steel), and they are refining how to deal with it.
This was first seen by the upgrade of the case halves from 5 screw to 6 screws to hold them together better during thermal expansion. Also, the early case screws in 2011 were gloss black, not flat black, and they would back themselves out.
To combat some fuel delivery issues the fuel lines were shortened and the carb changed from a Walbro el44 to an el46, and then ~mid 2014 to combat some hot-start problems it changed to an el48. The major differences in these carbs are the throttle plate and idle valve and software.
The fuel tank vent valve originally used to be routed up to the carb area, presumably to put the opening in a cleaner area when cutting, but the line has since been removed and the tank vents right to where the nipple on the side is.
There were some minor adjustments to the cylinders, with more "meat" around the intake flange, possibly to compensate for air leaks developing but masked by auto-tune. As well as some changes in fin placement and size, although this could simply reflect changes in mould supplier. The transfer covers were supposedly leaking and their shape has changed a little.
Supposedly the piston ring material has changed between 2014 and 2016. As well as an issue with 2013 models having the ring locating pin backing out within the first 75-100 hours.
The cylinder base gasket in 2016 incorporated both a paper gasket material as well as a silicone gasket to compensate for uneven case halves.
The plastic top cover in 2016 has cut-outs near the decomp to allow heat to vent away from the cylinder more.
There have also been several revisions (at least 2 I'm aware of) to bearings on both the flywheel and PTO side.
Simondo
5:48 AM
UK
Most are, the 560 uses different bearings from the 562 however.
Please correct me if i am wrong but I think the 562 now uses the same bearings as the 560 ...IPL 2017 has the 525 43 42-03 and the 505 13 35-03 showing as a sub on the 562.
Crane
12:48 AM
southwest Michigan
My 357 is in a shop getting an updated carb.
I looked at the 562 as I truly liked the 357 before having trouble with it.
But after reading this post how would I even know what version of 562 is new on the shelf?
All the changes, maybe this saw is not for me, and I need to look at Stihls.
A100HVA
12:48 AM
CENTER CONWAY,N.H.
the serial number will tell you the version based on when it was MFG.
