brandonstclair20
- 5:03 AM
- Nov 21, 2016
- Starkville
I took the muffler off of a running 064 I just purchased. I saw a scored piston so I took it apart. With some careful work with, fine sandpaper, scotchbrite and a Brillo pad I cleaned up the cylinder. Nothing catches a fingernail. I ordered a new oem piston on Monday. I know an air leak most likely ruined this piston. I closely examined the big end bearing and saw nothing wrong. The crank bearings are smooth. I did not see any debris in the case. I forgot tiny dents in the piston and tiny dents in the roof of the cylinder. What else could be going on here?
Thanks
Thanks
