ELECT6845
- 2:36 PM
- Dec 28, 2015
- INDIANA
This is one ugly saw but it runs good. Compression is 135 and the piston and cylinder look good with the muffler pulled. Pics of the piston and cylinder are posted. As you can see the plastics are cracked and very badly faded. Tank is almost brown along with the starter/clutch covers.
It will need a chain brake handle and brake band. Upper AV mount is bad and the others should be replaced as well. Handle bar rubber is brittle and has cuts all over it.
Bearings felt tight but without the seals pulled its hard to really tell. Sounds good when running no bearing noise. I do have a vid of it running that I can text to you if you like. Saw may need other repairs but this is what I have noticed.
****VERY WELL USED SAW THAT I HAVE NOT CUT WITH. YOUR BUYING THIS ONE " AS IS"
Price is 650.00 obo plus shipping. May trade for 60+cc saw.
