chainsawman2011
- 9:40 AM
- Mar 25, 2016
- Michigan
Ms270/280 parts
Im pretty sure it was a ms280i with easy adjust case and side cover
The good:
Fuel tank
Crank case
Crank with piston
Carb with air box(will need carb kit)
Flywheel(key not sheared)
Ignition coil
Working recoil
The bad
Cylinder is good bore but has broken fins
Missing alot of parts
No handles
Or cover plastics
As is parts lot $120 shipped
The good:
Fuel tank
Crank case
Crank with piston
Ignition coil
Working recoil
The bad
No handles
Or cover plastics
