STIHL MS 400
BTREE
Active OPE Member
9:20 PM
Idaho
First time poster
I just wanted to comment on the Stihl 400.
Bought one about a month ago, my goal being to replace my sorta awesome ported husky 562.
Reason to replace - I have tried every update/mod I have seen over the years and never gotten rid of the bog off of idle, and often it dies. Believe I bought this in 2014.
Not an ideal situation when falling or dropping chunks out of a tree from height!
So on the 400 - Added a bark box and foam filter setup and west coast dogs before it cut wood, so have no experience with it as a true stock saw.
Starts great, does not bog or die, and comes very close to keeping up with the ported 562.
Running 28 in bar on these in 22 inch log playing around and I would say the 562 beats it by about a second or two at most. But you have to run the 562 with more finesse- it’s easier to stall in the cut if you try and push it. Where the 400 definitely has more torque and is cutting at a little lower rpm.
Overall- for real work - especially critical work, the Stihl 400 is now my go to saw for chunking trees down and falling the smaller ones.
And the weight is identical when filled with fuel n oil! 400 has the 362 wrap on it and the 562 has the husky wrap on it.
I am sure a ported 400 would be awesome!
Sorry for the long post!!
Sierra_rider
9:20 PM
State of Jefferson
I've got a 400... originally my plan was for it to be my rear handle for climbing. With the wrap handle kit, it's my go-to saw for almost everything now. Besides the wrap handle, I've muffler modded it, foam air filter, 461R oiler parts, and did some minor port/machine work.
At my actual job, I mostly run a 462R. I think the 400 gets compared negatively to the 462 too often. They are similar in weight, but the 400 is still 1/2 lb lighter and feels lighter than that IMO. The power isn't too far off either...until I worked over the 462, my ported 400 was actually stronger.
Mine has no issue with a 28"lwb...it could actually run a 32", but I've got my 500i for that.
Ittybittyfitty
12:20 AM
Michigan
How hard of a job was it to change out the oiler for one from a 461R?
sawmikaze
12:20 AM
steeltown
I don't think people dislike it, I think stihl should have given it a better AV and oil pump considering it has the biscuits for a bar bigger than 20"
After you buy that wrap kit for a 400 you almost bought a 462. And considering you can buy a 462 from the factory with a wrap handle and adequate oiler for bigger bars it's for the most part a better buy over a 400 for a few ounces...plus it has more balls.
There's no ported 400 out there that's gonna pull a 28" like my last 462 Kevin ported, it's ALMOST my ported 461 with a 28" bar.
Sierra_rider
9:20 PM
State of Jefferson
Pretty easy. I kept my stock oiler housing and 461R control bolt and the rod in...the hardest part is getting the roll pin in/out, which isn't that hard. If you don't mind spending the money, you could just get the whole 461R oiler assembly. I should bolt up and then you don't have to take the oiler housing apart.
Ittybittyfitty
12:20 AM
Michigan
Cool bud. I’ve built and modified lots of pew pews in my days which require roll pin install and removal. As a result I have some roll pin punches which should help so long as I have the right size. How much did you spend in parts for the oiler upgrade?
Sierra_rider
9:20 PM
State of Jefferson
It was several months back that I did the oiler upgrade, so my memory is a little fuzzy...IIRC the parts were only $40ish, but I could be off base on that.
Stihl Potlicker
12:20 AM
P.A.
Semotony
11:20 PM
And my 460 speaks better than a stock 661, with muffler mod internal and dual port cover on my smaller cc saw. My ported 661 is whole nowhere deal lol
Semotony
11:20 PM
I didn't follow you at all on this one, Pilgrim.
A man with a 661 was not as fast in the cut, same size bar, as my 046 with muffler mod. On the other hand I want to show him the ported 661 hehehe lol. spellchecker took nother into nowhere. I forget to check up on spell check before posting
Woodpecker
Sassy Madam
12:20 AM
What size bar?
12:20 AM
Years ago, my modded 10mm 044 embarrassed a modded 066 that the pro tree guy bragged "was not stock". We were both running 28" bars in soft White Pine that did not slow my 044 at all. There was a very noticeable difference in how fast my 044 went through the rounds.
I think my chain sharpening skills were better than his, and IMO his muffler mod did not look to be well thought out.
But he was bragging up a storm about how strong his 066 was before the cutting started, and got real quite after the cutting began, as we were often working side by side. My brother had hired him, and he told my brother that I did not have any saws that would compare to his 066.
I understand that a longer bar +/or harder wood would favor the 066, but you go with the task in front of you. For this project (we had to clear a path for a bridge over a stream) my 044 was hands down the better saw.
The vast information on sites like this give us a leg up on a lot of professionals who never go on sites like this and never learn what we know. I'll bet he did not even know what square file was!
