SteveSr
- 10:26 PM
- Dec 14, 2016
- North Carolina
I received this from one of our volunteer trail crew with the complaint that it would barely run. New air filter, sparkplug, OEM carburetor, cleaned spark screen made no difference.
Valves were a bit loose but adjusting them also made no difference. Pulling the rope feels weak even for a 4-mix.
Pulled the muffler and the exhaust port had some black carbon in it but didn't look too bad. Spark plug looked oily and black. Top of the piston through the spark plug hole looked oily and black but could see aluminum piston in spots.
I improvised a leak down test with my Mityvac tester and spark plug adapter. I could hear air leaking out the exhaust valve. When I covered the exhaust port with my thumb I could hear gurgling through the carburetor.
So obviously the valves are leaking somewhat, probably due to carbon buildup. Is there any way to fix this without a complete teardown of the engine? Is it too late for Stihl's engine decarbonizer? Anything else worth trying?
Extra Credit:
1. What is wrong with the photos below?
2. Did/does it have anything to do with the current problem?
Extra Credit:
