HELP! Stihl 076 AV Super- Bogs and Dies When Hot
lehman live edge slab
Live Action
1:43 AM
Mn
The newest 076 ipl I have showing the different ignitions used on bottom
Live Action
1:43 AM
Mn
The latest ipl of the 076, shows the two different carbs and the extra spacer and different air filter surrounds because the super ran an extra 1/2” spacer and walbro carb vs the tillotson of the 075 and standard 076
chilipeppermaniac
2:43 AM
Md
You could always test the ignition and retrofit it with a module
BuffaloBill
1:43 AM
Wisconsin
Have you found a solution for your lack of spark? I fixed up an 076 Super a few years ago. Its main problem was no spark. The coil seemed to test ok so began searching for a replacement trigger plate. Mine has the doughnut-shaped one. I did find an NOS one on eBay. It’s run fine since replacing that and restoring the saw.
I x-rayed the failed doughnut at work, thinking I would attempt to draw out the circuit someday from the x-ray pics, and dig into the potting compound to replace the failed components. I assume this one uses an SCR as the switching component. Below find pics of said trigger module, and the saw.
