ppxstnr
Active OPE Member
- 11:49 PM
- Apr 5, 2017
- South Carolina
I have a Stihl 064. It keeps blowing the seal on the Clutch side.
I figure it's either a crank that's not straight, a ruff spot on the crank, too much bearing play, or I have not installed the bearing or seal correctly.
This saw is a play toy , so it's had bearings installed several times. The current bearings are Stihl oem and are less than 6 month old. Seals too.
I did a vacuum and pressure test and the seal was leaking, no real visual signs tho. I replaced it. The saw pressure/vacuum tested good. It ran fine for about 5 mins of cutting, then went lean, wouldnt idle down.
I can do a lot of time intensive testing, but was wondering (from those with experience) what the most likely culprit could be.
Thanx
Thanx
