DarrenS
Active OPE Member
I've a 044 that i was fixing up, put it all back together, set carb at 1 turn out for each screw, starts fine, idles ok at approx 2400rpm but at high it's at 15,100rpm whereas it should be 13,300.
I've pressure & vacuum tested for leaks and it held up fine.
So why is it over revving?
I can turn the high screw out to 2 & 1/2 turns and it revs at 13,300 but at that it's throwing a lot of petrol mix out the back, towards the air filter, so somethings not right?
Any ideas would be appreciated.
