Scotty Overkill
Serial Tree Killer
- 8:32 PM
- Jun 14, 2016
- central PA
Heres a quick run-down on the saw....
I rebuilt the saw from a box of parts around 14 months ago. AM piston, Hy-Way nickasil cylinder, Caber rings, new crank seals when rebuilt. Saw ran pretty well, only mods were a slight timing advance and a muffler mod. Nothing else. It did break a set of rings when i first rebuilt the saw thanks to a lousy casting on the exhaust port, I fixed the port (amazingly no damage to the P/C) and replaced the rings, ran perfectly fine. Was a reliable saw, great for bucking tops.
Ran the saw flawlessly up until this past August when I had to buck a top that landed in a deep creek. I sat the idling saw on the log after making a cut to catch a floating runaway round, and the saw slid off the log into the creek while running.
Drained it, and let the saw dry out, and it would run, but was really finicky. Then, after using it a few times afterwards, it quit altogether. I figured maybe it sucked water in and pushed the seals out, so I parked it.
Three weeks ago I tore it down, and sure enough the flywheel-side seal was pushed out and into the flywheel. I pulled the seals, pulled the jug to check for damage, replaced the fuel line while it was down, replaced the carb (original one was beat up pretty bad), installed new crank seals on both sides, replaced impulse line, replaced the coil with an AM version, and ported the cylinder and transfers mildly while it was out, did a base gasket delete, and put it all back together.
Had it running a couple time this evening, but the bastage shuts off like a switch out of nowhere, so I pull the spark plug and find it wet-fouled....and it does it relentlessly, over and over again....I had it running long enough to get the carb tuned pretty good, so I'm pretty much ruling the carburetor out.
Should I closely inspect the crankcase gasket? I pretty much did everything else to this damned thing, I'm fixing to give it a good toss here soon.....lol
Any idea fellas? Thanks in advance.....
