WANTED Stihl 020T OEM crank bearings!
IffykidMn
2:01 AM
Minnesota
Looking for a set of new OEM crank bearings or a possible lead on where a set may be found?
Thanks
Scotty Overkill
Serial Tree Killer
3:01 AM
central PA
I've yet to have to replace them on any of my 020T/MS200T's, maybe check a dealer or go to CCC's website site and see if Dave can source you a pair.
Scotty Overkill
Serial Tree Killer
3:01 AM
central PA
Hmmm I will have to check a different dealer I was told they are different. :rolleyes:
They
Pretty sure they're interchangeable, the cases to my knowledge are identical other than the 020T is a screw-in oil cap, the MS200T is a flippy cap.
Ketchup
Epoxy member
1:01 AM
Colorado
Definitely possible they have different part numbers. I’m pretty sure the bearings are the same 020T, 200t and even 201t. It’s also pretty rare for them to go bad. I’ve seen way more bad cranks than bearings in those models.
IffykidMn
2:01 AM
Minnesota
Have not split the cases but with slop in the crank I figure it would need crank bearings and would look to see if OEM bearings are available or not first, going by what others have said aftermarket bearings are not worth bothering with.
Lone Wolf
3:01 AM
Nj
Do you see up and down play or side to side play in the crank when checking?
IffykidMn
2:01 AM
Minnesota
Side to side is normal in those. But the seals should be replaced and then vac test it.
Yes to the seals, vac leak at the seals is what prompted the tear down just figured I would throw in new crank bearings, seals, wrist pin/bearing, piston and rings while I had it apart and from the economy side it would probably makes more sense to just do seals, wrist pin/bearing and rings.:hsughwiggle:
Lone Wolf
3:01 AM
Nj
Does it really need a new wrist pin bearing?
JD22
12:01 AM
California
I love these chainsaws, I’ve got a few 200t builds on the bench now. Full oem rebuilds
